Discuss vokera vibe 20 a and visions. emmisiions high ppm ... in the Gas Engineers Forum area at PlumbersForums.net
markinaark
vokera vibe 20 a and visions. emmisiions ie ppm in the thousands on low rate safety check . any one coming across this, and offer a remedy a solution, recomendationto correct for same..... in the process floods anaylsers...and makes it extremly difficult to calibrate.
m.i. states .. co2% should be 9.00 and 9.5...... ie high and low etc . but when set to low. produces 1000s ppm floods anton anaylser ... so to try and adjust with allen keys .....is not a possibility .....
I’ve had this twice with Vokera Vision System boilers ( the current version with the LCD display, not the early version with no display) - one, a 25S was straight out of the box.
If you call the Vokera service line, they will come out and replace the suspect part. Free of charge in both of my cases - it is a £350 ish part on an £650 boiler, so you can no doubt guess what it is.
I was told that the indication that there is a problem is a build up of white milky deposits ( with solids) in the condensate pipe that connects the collector to the condensate trap.
Have seen that white goo in lots of them. When doing trap... Always wondered how that came about
Reply to vokera vibe 20 a and visions. emmisiions high ppm ... in the Gas Engineers Forum area at PlumbersForums.net
I was wondering if anyone can help with this. On servicing a two year old Vokera Unica i28 I carried out combustion analysis checks. The high...
The compact, easy-to-use testo 340 available from CORGI direct enables you to carry out emission measurements on industrial combustion and power...
1K
  • Locked
I have my initial gas safe inspection coming up after successfully completing my ACS a few weeks ago - and, it's fair to say i'm slightly nervous...
4K
  • Locked
WITH ALL THE REGULATIONS IN PLACE THESE DAYS, WE MUST BE SAFER NOW. AS YOU WILL SEE FROM THE (CO) CHART AT THE BOTTOM WITH ALL THE SAFER DESIGNS...
7K
M
  • Locked
sorry about the wait for my epic story, didnt realise you get timed out in the writing something section. wrote this earlier so hopefully copy and...
Whyme
W
