Discuss Warmflow 70/90 Bluebird recommended nozzle and angle in the Oil and Solid Fuel Forum area at PlumbersForums.net
installed a warmflow 70/90 bluebird boiler with a 0.55 x 80 degree nozzle.
boiler is only heating 5 radiators in a small 2 bed house.
what is the recommended nozzle size and pitch for this boiler?
Can I change the nozzle size and pitch to use less oil as the flame is hitting the back wall of the boiler and radiators are getting too hot?
thanks.
It will tell you in manufacturers instructions what size nozzle to use to de rate it.
A 70/90 will be factory set to 80,000 btu's but they give you the info for the 70,000 and 90,000 btu's output.
Reply to Warmflow 70/90 Bluebird recommended nozzle and angle in the Oil and Solid Fuel Forum area at PlumbersForums.net
PSxxxxxx
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
