Discuss Washer jammed - advice please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
13Black
Hi, would appreciate some advice.
I had a worn washer on the hot water tap, which was leaking slowly.
I removed the tap body and took it to the plumbing shop as I didnt have right size rubber washer. The guy fitted a new washer for me.
I put the whole thing together again and it was fine for a couple of hours and then no hot water. I took the tap body out and realise that the washer has come out from under the screw that it is supposed to sit into the tap body and is now jammed in the interior of the handle body.
I can see the rubber valve jammed in place and have tried to wedge it out but it is fairly firmly lodged. Any tips on how to get it out?
Apologies if I have got the terms wrong when describing. I just need to know how to get a washer stuck out. Is it a case of getting a sharp knife and working away on it until breaks and prying it out or is there an easier technique.
I think I have learned the hard way that you need to use the right washer. When the guy fitted it, was not flush in terms of its depth. I have taken the tap body out of the cold tap and realised the difference.
Thanks in advance for any advice.
Often just have to butcher it out with a slotted screwdriver.
Sometimes just pushing the slotted blade into the washer hole will let you pry it out.
A pair of long nose pliers are great for reaching the washer.
Perhaps you have used a 1/2" washer on it instead of a 3/8" ?
Thanks Subby. I triedthat but the sucker is lodged in tight. It wont budge, hence the thread
Thanks for the reply Best. He said it was 3/8 but as I said it didnt fit flush under the screw ie. it wasnt flush with the "casing" it sits in.
Then looks like you will need a hammer & sharp slotted screwdriver to cut it in 3 or more bits!
Brut force. I can do that! Will give it a go tomorrow.
Sorry if this is a daft question but do different taps have different depth washers? When I've done this before, the washer hasnt needed to sit within a cashing. it simply slotted over a spindle.
Depth of washer usually not too important, but width (diameter) can cause them to spread too much & jam.
You might have to look around for exact size washers
is it a daft idea to take the washer out of the cold tap (which is working fine) to see exactly what I need? i cant tell as the one in the hot tap had split and hardly anything was left
Reply to Washer jammed - advice please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Sorry if it is a dumb question but .. I just fitted a 1/2inch tap washer to my basin tap and have 2 questions. 1. Is it normal for the...
Hi guys, Looking to replace an old shower diverter. Pictures attached. I'm from Australia if that makes any difference. Originally when i got...
Hello, Renovating downstairs bathroom, we have changed the layout and I just wanted to confirm if what I want to do is appropriate. I want to...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be...
3K
