Discuss Washing machine vibrations in the USA area at PlumbersForums.net
Hey guys.
What's the best way to absorb washing machine vibrations?
It's currently on a suspended floor and sounds like a rocket take off.
I've got lots of polystyrene I could put underneath to absorb vibrations or any other material you could recommend.
Many thanks
I have not tried these so please make your own mid up on whether or not you think these might help. I've had a search and whilst some people have tried rubber/neoprene and similar mats, they don't seem very effective. This stuff came up on my search though!
Diversitech MP-4E EVA Anti-Vibration Pad 4x4 inch Square by 7/8 inch Thick | eBay
E.V.A. is not affected by oils or chemicals that can break down cork and is much more effective at vibration dampening than solid rubber.www.ebay.co.uk
It looks like it might be quite effective. A washing machine is a very heavy and powerful piece of equipment that is hard to quieten down but pads like that under the feet or taking place of the feet might make a difference.
Washing machine fixing kits are also available but they are more to stop them wandering off on spin cycle and I don't think they will reduce much noise/vibration to the floor.
First, remove the shipping bolts at the rear (shipping bars in the older machines) before plugging in.!!.
And level it up properly, usually the adjustable feet will do it, check mi's.
To slide it in and out on a hard surface, tile, lino etc, use a dab of fairy on the floor for lube
Have you put a level on it - All sides
Or it's faulty, they have systems in them to get the load evenly spread before they spin, I say check level again
[automerge]1583659687[/automerge]
Have the floor up and fill the cavity, search "drum effect"
Reply to Washing machine vibrations in the USA area at PlumbersForums.net
