Discuss Waste Accumulating After Flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TPWARD
Hello,
I was wondering if someone could please give me some advice? I live in a rented property and previously had a toilet with a very weak flush, so we got the landlord to replace it as after going for a #2 we were having to flush around 8 times just to clear it.
Since then we have had a new toilet fitted but this is also having problems. It is as though the toilet keeps getting blocked. Eve when it seems to have cleared, the next time it is flushed the water in the pan fills to the top like it is blocked. I have then used the cleaning brush to try and pump it clear, but then loads of waste from say 12 hours earlier comes back up into the toilet, so having flushing it seems to block it and won't flush properly. It is not as though the waste is exessive either. It even happens with minimal paper by itself.
After having had the waste back up into the pan, I have been pouring large buckets of hot down it too and it goes down no problem. However, the same problems comes back again the next time.
Does anyone know what this could be? It is an absolute nightmare.
Thanks a lot.
Have you tried a high fibre diet
Seriously tho..
What type of connector is on the back of the pan and does it go direct into the stack ?
Haha...I was waiting for something like that...haha! I am afraid that I have absolutely no idea, as you can probably tell I'm not a plumber. I will try and take a photo.
I'm on my phone so can't upload an image but will do tomorrow. Cheers
theres a root ball blockage in the main drain outside enough to clear water through but not solids.
look for the tree or bush.
last one i found was just inside pan connector about 8'' in, it was three foot long when i pulled it out !!
could also be badly constructed waste pipe-run if not!
There is a restriction in the main drain run somewhere get the landlord to get a drain company in they can put a camera up the pipe to find the problem and clear it
Reply to Waste Accumulating After Flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming...
My toilet flushes ok when the long flush button is pressed - but water continues to flow into the toilet bowl. No problems with the short flush. I...
J
I use flushable wipes and I know that there has been previous advice not to flush them but it says a new and improved design allows them to be...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
