Discuss Waste Fitting Waste trap question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andy.davids
Can anyone explain how to add a waste trap to this sink please. The sink is stone and the only access is from below (shown). There is no plug.
Find some way of siliconing a trap to it?! May need to cut a flat face to it so it has a bigger surface to attach to underneath? Wouldn't like to try it myself though. Surely there is an actual fitting for this type of instance?
presuming thats a basin not a sink, but go back to your supplier or the manufacturer for advice
why is there no access from above? can you post a picture so we can see from above pretty please.
Stainless steel or polished chrome tundish with a rubber seal (5mm) then off to an architectural trap. Will all need to be supported and rigid. Alternately a bucket? But mfr should tell you. Isn't it in spec?
Thanks for your help. Here is an overhead pic. I will try to get to the shop today to ask.DSCF0330.jpg
How the hell are you supposed to wash in that ? look flash but not practical .
Surely a bathroom like that has it's own Ensuite with proper sinks in??
As smart as it looks, I'd never get my feet in the one in the O.P
Given it's style it's going to need a very discrete waste setup and no grid in the waste
I'd be looking at getting a Hep waterless with elbow to keep the trap and pipe well up under the basin.
cut the grid out of a short shower waste and epoxy resin glue it to the bottom of the basin
Reply to Waste Fitting Waste trap question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
