Discuss Waste Pipe Dimensions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
laurel
Hello Everyone.
I have a plan for a downstairs bathroom showing one pipe leading from the soil and vent pipe, to a toilet and then onto a basin. Should I try to reduce the size of the pipe after the loo, or try to connect the basin to the 100mm pipe? Or could the drawing be wrong and should I use two seperate pipes for the toilet and basin?
Any advice would be much appreciated :)
Laurel
how is the pipe being run, under a floor? surface along a wall?
you will be better off runing a seperate 11/4 waste to the basin connected into the svp, you can get pan connectors that have a 1/14 connection on for a basin which maybe your best soultion. if you go this way then id fit a basin trap with an anti vac valve to avoid problems with the water seal getting pulled away.
the toilet waste is 110mm! you can boss a connection into it (32mm) for a basin, or you can get w/c pan connectors with a built in boss for basins. check out mccalpine products for this
KJ
Thanks very much guys :)
I found a fitting on McAlpine which I think will work.
Cheers,
Laurel
Reply to Waste Pipe Dimensions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
B
My soil pipe on the downstairs toilet seems to be partially blocked. Now I know it can be rodded but I was thinking of another way. With the...
We have a problem with a downstairs bathroom toilet. When flushed, the water in the bowl rises, as does the water coming up from the shower drain...
My bathroom Basin was installed some years ago by a professional plumber. For whatever reason, the waste was fitted using silicone rather than...
Hi could anyone give advice please ? I went to look at a new build for sale they are apartments/ one house on top of another all properties will...
