Discuss waste pipe - minimum distance from stack? in the USA area at PlumbersForums.net
Im installing a wall hung toilet frame and just working out where everything needs to be positioned etc.
I want to move the frame/toilet over to the right as far as possible but can anyone tell me if there is a minimum distance that should be used for a straight run before going into the branch?
Could I have a 90 degree bend coming off the pan going straight into the branch with the shortest possible 'tail' to fit into the branch socket?
Would there be any potential problems in trying to do something like this?
the grey pipe/white socket is the old waste. I want to move everything over to the right as close as possible to the branch
Cheers
Cheers.
also need to 'lift' a branch enough so that i can connect it up to the waste outlet of the toilet frame. ( this ones in a different room)
The gap is about 100mm.
Not able to drop the frame any further as i need the floor clearance to mount the pan
Below the branch is another socket which is fixed due to the shower waste outlet. The Socket above will be for the basin waste then above that, the rest goes up to the svp.
If i cant fit a short section in with a slip coupler what other options are there to make this work?
was thinking of trying an adjustable socket bend like this?
any other suggestions?
If it’s pushfit below just raise the outlet
Reply to waste pipe - minimum distance from stack? in the USA area at PlumbersForums.net
