Discuss Waste pipes for bathrooms and kitchens in the DIY Plumbing Forum area at PlumbersForums.net
Hello,
Can you use uPVC for bathroom and kitchen waste pipes. Or should it always be mupvc?
Regards
Tezzer
Pvc or abs
Thanks Shaun
Just to clarify. Are we saying that any pvc I.E uPVC is up to the job in terms of handling everyday kitchen usage namely hot water etc.
Regards
Tezzer
When I say kitchen usage I mean from a water pipe prospective, supporting everyday appliances etc. If some can confirm if this is ok It would be very much appreciated.
Is there a really good reason you're not using standard off the shelf plumbing waste pipe.
You have prompted me to have another look on the pipe itself. It is actually just PVC and not uPVC. Not sure where/why i suddenly incorporated the “U”. On that basis I assume standard PVC is fine for a residential kitchen waste?
Yes only time I would use mupvc or poly prop eg push fit is if your using a boiler tap eg instant hot water
Both uPVC and mPVC can be used for bathroom and kitchen waste pipes. uPVC pipes are highly durable, have excellent chemical resistance, and are lightweight. mPVC pipes are modified for higher temperature applications and offer similar benefits. The choice between the two depends on specific requirements and preferences. Both materials meet the necessary standards for waste pipe applications.
Thanks for your input Daniel
Reply to Waste pipes for bathrooms and kitchens in the DIY Plumbing Forum area at PlumbersForums.net
Hello, Do different PVC pipes I.E PVC and muPVC weld directly together? Regards Tezzer
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Hi, a couple simple questions. 1. I have two pipes like seen on a attached photo in my back yard. One is for the waste from kitchen, the other one...
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can...
