Water dribble when soldering
View the thread, titled "Water dribble when soldering" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I'm a complete notice and I working on my heatings motorised valves on my S plan system. I was modifying the system to add an arrester. Long story short, I made a bodge of the soldering due to persistent tiny water dribbling in the pipe being soldered which I overlooked despite the system being drained. How does one get around this? I heard of people using bread but that won't work here I won't be able to retrieve anything from the pipe afterwards.
Using bread is fine as it just dissolves in the water when filling so you dont need to remove. You don’t need t use a full loaf though just enough to soak it up to stop the drip. But failing that as already stated use compression
Or press fit.
Or get a small bore hose, insert in to pipe and blow/suck the dribble, then solder quick before it comes back.
Or open a drain off/compression near by to divert the drip.
Reply to the thread, titled "Water dribble when soldering" which is posted in UK Plumbers Forums on Plumbers Forums.
red_rover,
Timmy D,
