Discuss Water in pipe when soldering solutions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello Lads/Lasses
New to the forum so are with me
What effective methods do you lot use to stop water dribbling out of the pipe when trying to solder a new fitting as a repair
cheers
ct9plumber
i've found a bit of bread to be effective(no joke) if it is just a trickle, if there is more then i get my wed and dry vac out and give it a good suck then quickly solder the fitting on. oh and welcome to the forums.
I've heard the same thing with bread. Apparently you can get some sort of fish bait thing (not a fisherman) and whack it in the pipe. Plus stores quite well in tool box and means you get 100% of your lunch.
if its a vertical pipe so long as the flow is stoped a fabreeze or similar spray head clears enough water to be able to solder
Try and push the pipe in a direction to drain as much water as possible. The tilt or push the opposite way to solder. Sometimes I push my gauge tube down and blow it out, and always have an open end.
plus one for the u gauge tube or on vertical 22 a bit of 15 can be used to pull water out by putting in finger on the end and lifting out
place the tube that is below the squirty head when you unhook it from the bottle in to the pipework then spray away
Reply to Water in pipe when soldering solutions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Sonya K
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
