Discuss Water issue in outhouse in the USA area at PlumbersForums.net
Sandeep89
I'm having an issue with water in my outhouse. I have a sink in the outhouse with a mixer tap and a undersink water heater.
There is a blue pipe going underground into the outhouse from the main house to supply water connection to the outhouse. For past few days the tap in the outhouse has stopped working however anytime a tap is opened in the main house the tap in the out house starts to work.
Any ideas what the issue could be?
Is there a pressure reducing valve on feed to outhouse? I imagine there is. If installed the wrong way around this could happen. Had the same on an old oil combi. I initially installed the PRV the wrong way around (the combi cold pressure needed to be reduced because the excessive pressure was eating seals). Only when dynamic pressure in the rest of the house dropped below PRV setting did I get flow to boiler.
There is a prv reducing valve which is connected on the incoming cold feed pipe in the outhouse which then is plumbed to the undersink water heater and cold tap.
I will have a look at it.
There will be a direction of flow arrow on the valve, this should coincide with the cold main flow.
It is possible the valve worked up until now but the incoming main pressure to a property can change at any given time, this is down to the waterboard and you have no control over it.
So we had a new water meter fitted few days ago and it started after this so may well be the flow direction has changed.
I will have a look tomorrow. Thanks for the help.
Reply to Water issue in outhouse in the USA area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
I live in Azerbaijan and am looking to revamp the water system in my house. The first thing is that I don't have a water meter - probably a good...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hi all. Just had a neighbour knock the door regarding a water hammer issue. My own house developed this issue sometime last year as well which is...
