Discuss Water keeps running out of pipe? in the UK Plumbers Forums area at PlumbersForums.net
Which prv valve do I replace it with? The one on there now says SYR 016. Also do I just undo the big nuts for that SYR 016 prv valve because on my one there's a part where there's that little nut with the tape in between it & the body of the valve whereas it doesn't have that in the pics of it when searching online.To save it freezing and busting the pipe, prv will run / blow before the pipe does
Also need to tighten the push fit collar on it as it’s loose / slacking off
Reply to Water keeps running out of pipe? in the UK Plumbers Forums area at PlumbersForums.net
