Discuss water leaking in lounge in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
Maureen
Water leaking under skirting board in lounge between telephone point and radiator for 12 days
Reply to water leaking in lounge in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Does anyone know a good, not super expensive, leak detection company in the London area?
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
