Discuss Water pressure problem in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. leiadad
    leiadad GSR
    Hi could someone help me decide on correct mains water pump to use. I am doing some work for a guy who wants to increase his mains pressure. At the moment he has got a static pressure of 2 bar. At full flow he has a dynamic pressure of quarter of a bar at 26 litres per minute and is saying he is unhappy with this pressure. The flow he is happy with. He said at peak times his flow will go down to a dribble at some outlets, although I didn't see this as I checked during day. I checked flow and pressure straight from stop tap which is brand new. He has also just had new alkathine pipe put in. I was having a look at stuart turner pumps which have an accumulator attached. I don't think the accumulator would be needed much though as the flow is there anyway. It says in spec that it is 3 bar pressure and I wanted to know if this pressure is a dynamic pressure and also how would this work If going through combi. Thanks
  2. ShaunCorbs
    Yea something like a flow mate should work
    How much space you got ?
  3. leiadad
    leiadad GSR
    Got enough space I think m8. Have you fitted this pump before, did you notice a big difference when using pump before?
  4. leiadad
    leiadad GSR
    Also would you buy pump on its own or would you add in the accumulator
  5. ShaunCorbs
    Yo can just buy a pump and put it on the mains your limited to 12lpm max if you pump it
    You need to buy the proper kit
    Stuart Turner
    If you have the space
  6. leiadad
    leiadad GSR
    Yeah that's ok as I am getting enough flow anyway, what kind of dynamic pressure would you be looking for shaun as a good pressure also how would you have checked the pressure and flow. Would you have done it the same way I did
  7. ShaunCorbs
    You can't pump direct from the mains eg by just putting a shower pump on the cold mains
    Flow and pressure standing
    Flow and pressure dynamic
    And I would install the system in my link
  8. leiadad
    leiadad GSR
    You can pump direct from mains using stuart turner pump
  9. leiadad
    leiadad GSR
    I don't know what you mean flow and pressure standing
  10. ShaunCorbs
    With just one outlet open eg the one your testing off
    Dynamic is having another one open while your testing
  11. leiadad
    leiadad GSR
    I thought standing was everything closed, is it not
  12. leiadad
    leiadad GSR
    I see what your saying but flow can't be checked while it is a standing pressure
  13. ShaunCorbs
    How you supposed to do the flow :D
    No but it's called standing flow and pressure test
  14. leiadad
    leiadad GSR
    You said earlier flow and pressure standing. Flow and pressure dynamic
  15. leiadad
    leiadad GSR
    What dynamic would you be looking for
Loading...
Similar Threads - Water pressure problem Forum Date
recent hotwater pressure drop to shower pump - help! Bathrooms, Showers and Wetrooms Sep 8, 2018
Water pressure issue Plumbing Forum Sep 2, 2018
