Discuss Water pressure problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
leiadad
Hi could someone help me decide on correct mains water pump to use. I am doing some work for a guy who wants to increase his mains pressure. At the moment he has got a static pressure of 2 bar. At full flow he has a dynamic pressure of quarter of a bar at 26 litres per minute and is saying he is unhappy with this pressure. The flow he is happy with. He said at peak times his flow will go down to a dribble at some outlets, although I didn't see this as I checked during day. I checked flow and pressure straight from stop tap which is brand new. He has also just had new alkathine pipe put in. I was having a look at stuart turner pumps which have an accumulator attached. I don't think the accumulator would be needed much though as the flow is there anyway. It says in spec that it is 3 bar pressure and I wanted to know if this pressure is a dynamic pressure and also how would this work If going through combi. Thanks
Yea something like a flow mate should work
How much space you got ?
Got enough space I think m8. Have you fitted this pump before, did you notice a big difference when using pump before?
Also would you buy pump on its own or would you add in the accumulator
Yo can just buy a pump and put it on the mains your limited to 12lpm max if you pump it
You need to buy the proper kit
Stuart Turner
If you have the space
Yeah that's ok as I am getting enough flow anyway, what kind of dynamic pressure would you be looking for shaun as a good pressure also how would you have checked the pressure and flow. Would you have done it the same way I did
You can't pump direct from the mains eg by just putting a shower pump on the cold mains
Flow and pressure standing
Flow and pressure dynamic
And I would install the system in my link
I don't know what you mean flow and pressure standing
With just one outlet open eg the one your testing off
Dynamic is having another one open while your testing
I thought standing was everything closed, is it not
How you supposed to do the flow :D
No but it's called standing flow and pressure test
For a decent flow I would be looking around 15lpm dynamic
Yeah that is your flow but I am assuming that you would be looking at a particular pressure at the flow of 15 lpm
Yea around 2 bar dynamic
Reply to Water pressure problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
