Discuss Water stains on WC in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Has anyone got any great ideas of how to remove water stains in a WC pan. The pan has been overflowing for while. It is fixed now but the constant stream of water has caused water marks at the back of the pan. Does anyone know of any wonder cleaner to remove it
Spirits of Salts will clean the pan but take care when using it as it is hydrochloricacid.jpg
Read & follow the instructions / data sheet.
It works a treat.
Cream cleaner should shift it
Spirits of Salts will clean the pan but take care when using it as it is View attachment 26474
It works a treat.
I have used brick cleaner at 17% Hydrochloric acid to clean stains from pans that were otherwise impossible to remove. Remember this stuff is harmful to the skin and devastating to eyes (as is the case with all strong acids or alkalis). With proper protective equipment - strong acid resistant gloves and googles/face shield and care this type of acid can be safely used.
Reply to Water stains on WC in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
