Discuss Water supply and drain cover query in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone,
Today a plumber came round to do carry urgent repairs in the kitchen but needed to turn off the mains water supply to the building since it is flats.
He went out to the front of the building and opened the water drain cover which is outside the front gate and on the pavement to locate the stop valve and shut the water supply off, however he was not able to locate it despite taking out quite a bit of debris and said he could only see a pipe but no valve.
  • Is this unheard of as should there be a valve and can the water company help with this?
  • Also I can turn off the water to my flat by turning off all the stop cocks and gate valve is this not sufficient enough or does the main water valve outside the building need to be turned off.
  • Will I need to pay for the water company to help with this?
  • I had my bathroom completely upgraded a few years but the mains wasn't turned off then or am I missing something?
I would appreciate any information or advice as I am at a loss what to do thank you.
It's the Water Co who should clear out the stop valve chamber and fix the valve if required.
And also identify where their stop valve is and if not found fit one.
Sometimes the stop valve location is lost, when pavements are realligned or resurfaced
None of that is chargeable.
Reply to Water supply and drain cover query in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the...
