Discuss water timer required in the DIY Plumbing Forum area at PlumbersForums.net
My central heating was installed in 1978. Over the years only two boilers have been used; installed a Kinetico water softener in mid 80s.
However when installed the upstairs radiators were run off the hot water system. This is no problem, till now, as we have never used the rad in our bedroom and the rad in our spare bedroom we just turn for winter and turn off in spring.
The controller we used for many years allowed us to control both water and heating via its built in timer; can't remember its name but when it broke some 15 years ago the replacement just plugged into the existing electrical socket.
About two years ago we had to call in a plumber to resolve a problem. He found that our control unit was faulty. He said that that type is no longer made but he could find something similar except no controlling the water; thought that would be OK. The unit is a Siemens RWB2E. We should have asked more questions, but just told him to find an ordinary controller!
We now realise that the only way to control the water is to operate the switch on the unit; difficult as the unit is in a cupboard under the stairs and the rad is upstairs, old legs creak!
What controller will allow us the control the heating and water under the timer. Perhaps we could go further and have independent control. We will get a qualified plumber to install.
Any advice please?
I would fit a wireless programmable room thermostat with hot water capabilities. The receiver would go under the unit, and the controller being wireless can go pretty much anywhere. A few that spring to mind are:
  • Honeywell T6R-HW
  • Hive dual channel
  • Drayton Wiser 2 channel
  • Heatmiser slimline
This Honeywell junction box has the following cables connected. Note unit to left is the Siemens.
Cables left to right
1) to Siemens
2) from zone valve
3) 240V in
4) connection to boiler*
5) to pump
6) from thermostat
7) connection to boiler*
*Two cables go through the wall to the boiler on the otherside; I don't know what they are connected to on the boiler.
If a Honeywell T6R-HW was fitted I assume the Seimens would be replaced with the Honeywell receiver box and the thermostat cable would be disconnected?
As this unit is in the very warm, in the under the stairs cupboard, would this affect the receiver box and with the metal around it how about wifi received? My wifi signal strength phone app shows a good 2.4Ghz signal at the Siemens.
I emphasise that I will not be fitting anything but would like to understand what is.
Note I turned off the power and unscrewed the plastic junction box cover to take picture; replaced cover then turned power back on.
Drayton lifestyle if you want just simple and should just clip onto the existing backplate
Yes the Honeywell would replace the Siemens, and thermostat wiring would be replaced with the switching wires from the Honeywell. You could replace with a simple time clock and just extend the wiring out of the cupboard?
@ShaunCorbs OP wants it to be easier/better access to turn on and off.
Reply to water timer required in the DIY Plumbing Forum area at PlumbersForums.net
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our...
2K
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
A few months ago I wanted to connect a 1000l water butt (fabricated from galv steel) to our washing machine. After trawling many forums and...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
