Discuss Water under laminate in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
Mr green
Found water coming up from under laminate floor in new bathroom. Once leak found should the bathroom fitter lift up floor dry and replace floor to stop mould?
Yes. Any pieces of laminate that have got wet need to be taken up and replaced with new. It is often difficult to get replacements that are a satisfactory match to the existing planks, in which case the whole floor should be redone.
The cause of the leak needs to be investigated properly to ensure there won't be a recurrence. For example, if the pipework is plastic, were the correct inserts used and was it properly pressure tested by the installer?
Don't be fobbed off. If in doubt, get another company to inspect the work and confirm everything has been installed in a skilled and proper manner and in accordance with manufacturer's instructions and applicable standards and regulations.
Reply to Water under laminate in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a hot water slab leak which is found behind my bathroom vanity. We heard the noise for a week but never saw any water. Just today we saw...
drpepper68
Bad leak inside bathroom walls at floor for three days. A gallon every hour. Shut off water for a few hours and leak stopped. Turned water back...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Bungalow built in 2001. All copper pipework (water and heating) runs in channels of expanded foam polystyrene between a concrete floor and OSB...
