Discuss ways i could link a wood burning stove to a conventional heating/hot water system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dennis.bailey
hi there,
in a nut shell, i have a customer that (like most of us) is complaining about the price of oil and gas etc. he wants me to link a wood burning stove to his existing system so that in the winter months he can just stoke the fire up and leave it on all of the time. Come the warmer weather, he will turn the stove off and use his conventional gas boiler to heat the place up if needed.
the boiler is fully pumped on both the hot water and central heating, and this is where i'm getting confused and frustrated in designing a system that will work effectively.
i want to ensure that both boilers remain fully pumped, and that he can have simple controls over both, that are safe and fool proof, i.e. he wont be able to stoke the stove up without pumps running etc.
thanks in advance, any help would be greatly appreciated. regards, Guy.
Have a look at the dunsley site and specifically the neutralizers. I priced one up awhile ago. Customer had a coal fire with back boiler and wanted it linking in with existing oil system. The jobs on hold, probably until it starts getting colder!
im pretty sure this cannot be done the main reason being if for any reason something goes wrong how do you shut off the fuel instantly as can be done with gas or oil say if it over heats etc
**: ways i *o*ld lin* a wood b**ning stov* to a *onv*ntional h*ating/hot wat** syst*m
i hav* **mov*d an old ba** boil** (o* so*ts) it was a *opp** box in a *oal *i** with 2 pip*s (*low and **t**n) that w*nt to a *opp** *ylind** via th* *opp** *oil to h*at *p th* hot wat** (th* ho*s* had no h*ating) th*** was a *old wat** inl*t to on* o* th* pip*s and a p**ss*** **l*as* valv* on th* oth** pip*. th* **ason it was **mov*d was it boil*d th* wat** and th* wat** in th* *old s*pply tan*
Re: **: ways i *o*ld lin* a wood b**ning stov* to a *onv*ntional h*ating/hot wat** sy
Have a look at this link. It's the controls side that is the fun bit. But it can be done and done safely.
New Page 1
Reply to ways i could link a wood burning stove to a conventional heating/hot water system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for a heating engineers/old school plumber to put in a Combi boiler (possibly Intergas) replacing very old open vent system in...
1K
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
1K
C
My parents house has a wood burning stove that is also connected to the central heating ( they have radiators and used to have an old boiler which...
1K
