Discuss WC connector to soil pipe in the USA area at PlumbersForums.net
I have a 3.5 inch salt glaze soil stack which I need to connect to a new toilet, I’m struggling to find a connector to fit inside the existing pipe, any ideas
I’ve never failed with a drain connector a decent application of silicon spray and either push it in or if it’s that tight a foot on it
Ian it a soil pipe, or floor drain connection? If it’s the latter, then you can use an extension b (mkea b) multikwik and bent pan connector.
Reply to WC connector to soil pipe in the USA area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
