Discuss Weird noise coming from Grundfos macerator in the USA area at PlumbersForums.net
Hey guys, hope you're all good
My macerator is making a strange noise which is hard describe so below is a link to a video to make it easier to understand the noise. You can hear the noise at around 10 seconds! I've checked inside the tank and assessed the motor and everything seems clear. The unit still operates as normal with the addition of the noise.
Should I be worried ? I am still under guarantee so I can replace the unit if the noise is a indicator of a failing unit.
@rpm I'm sure you might have an idea :D
Reply to Weird noise coming from Grundfos macerator in the USA area at PlumbersForums.net
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
I have a Grundfos MQ3-45 feeding my domestic water from a ground level tank (filled from an RO system from the well). The pump is about 4 years...
1K
Hi, I have a Worcester 34cdi boiler and it has started making a droning noise when it comes up to temperature or cycles. The sequence appears to...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
