Currently reading:
Wet patch on kitchen ceiling
Discuss Wet patch on kitchen ceiling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
robbieh
I've just noticed a small wet patch on the kitchen ceiling, about 12 inches away from the wall and around the size of a cup coaster. Directly above is the bath, and I have removed the bath panel and there is no evidence of splashes/leaking.
In the kitchen, in the corner, again around 12 inches from the patch, is the boiler. Is it possible a pipe is leaking going into there? If so, what can I do to sort it without expensive hassle that I cant afford?
If I removed a floor panel in the bathroom would I be able to see the pipes from the boiler? They go up into the ceiling area but I cant see where they go after that.
This is an even easier repair if you get problems in the future - - - -
15mm Pipe Repair Push Fit | NoLinkingToThis
However, I don't know how reliable it would be.
Edited in - - -
From the previous comment, seems it is 22mm pipe you have and not 15mm??
Don't forget your £100 donation to charity for the advice received on this forum ;)
If I bump into any of you, I'll gladly buy a few pints. Maybe some of you should set up a 'buy me a pint' paypal link.
Does anyone know why a copper pipe would suddenly develop a leak in the middle of a run, apart from freezing?
Thats what worries me. Like I mentioned in the OP, we do have water hammer, but I think thats to do with me fitting a new ballcock and valve in the loft tank a while back.
I usually blame the builders, westbury, they did a shoddy job putting these houses up. But in this case surely a copper pipe is a copper pipe.
Ask the plumber who is fixing the leak for you - no doubt he will check for corrosion or damage when he cuts the pipe.
I regularly get called out to a nursing home that gets pin holes in its pipe work (normally about 2am after the water has got into the fire alarms) Can be caused by just having some flux on the pipe, could just have been a slightly thinner wall on that section of pipe??
in future if you need a quick fix, cut directly over the pinhole and use a speed fit coupling
Like codcutter says a small bit of flux could be the culprit used to get pin holes on old steel pipes in boiler houses next to the cold feed coming in to the heating circs.
All sorted, the plumber just cut the leaky section away and used a coupling. I watched him do it and I'm confident I can do it myself in future if I ever have to.
Cheers for all your help and advice :)
I cant really tell by the picture how close the 22mm pipe is to the above flooring.Just wondered if it has been screwed or nailed from above.
Can the pipe be moved from side to side.Be careful though.
Reply to Wet patch on kitchen ceiling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
