Currently reading:
What are the extra inlet/outlets?
Discuss What are the extra inlet/outlets? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Buller44
Hi, came across this cylinder today! Customer asked what the two outlets were for. I didn't really know so thought I would seek some advice. Sort of established that the 15mm on the left is a hot water draw off but not sure about the 22mm above the primary. Hope someone can help :)
2ndry return, best to replace the speed fit cap end with a compression as lots of heat will degrade it in the long turn and it will become a primary drain, omho
Is the 15mm a secondary return and the 22mm for a shower connection if needed?
Haha, thank you guys. Makes sense now as they mentioned they used to have a shower running off the cylinder. Am back there on Friday so will cap it off properly. Thanks again.
Reply to What are the extra inlet/outlets? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
