Discuss What are you using to cut stainless 88.9mm pipe. in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Thank you. I've had a look and there doesn't seem to be many alternatives. I was hoping for something a little more portable but it looks like this is the way forward.Rems cento
I wouldn't trust my guys to deburr properly and safely. It also leaves me a big problem with hot work permits. The cento looks like the way forward, its a bit more than I wanted to spend as we will be back to 54mm after this job but if it makes the job easier it will be worth it.View attachment 76753We use these for most large pipe work (2 1/2" - 5") or a hand held 9" grinder if larger pipe
Flapper disc to clean burrs.
You can hire them by the day/week.The cento looks like the way forward, its a bit more than I wanted to spend as we will be back to 54mm after this job but if it makes the job easier it will be worth it.
I have 100m of pipework to replace with the onsite engineers and it has to be done in production time so it will probably take a couple of months on and off. We are probably saving £40k doing it ourselves so in the grand scheme of things £1200 for a decent cutter isn't going to break the bank and at least it should avoid the badly deburred pipe damaging the orings. Thanks for the advice everyone.You can hire them by the day/week.
Reply to What are you using to cut stainless 88.9mm pipe. in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
