Discuss what do you guys make of this in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
Is that rubber on the top of the flue ?
the above pic is ducting and at the bottom a fan providing the mechanical ventilation to a plant room, going through the ducting is a gas pipe.
even with the obstruction its providing ample air. the gas pipe is not sleeved and i cannot be certain if its a straight piece of pipe with no joints
going to hold off saying how i classified it as im interested to hear your opinions
I wouldn't like it either
I would hole saw into the side of that box and look to see what's inside. Then I would make a decision. Obviously cover the hole again after I've seen what's inside.
There are many options. One would be to sleeve it all the way through the box but you won't know what's possible until you've had eyes on it.
in the end i put it down as an AR, because it has no sleeve i was able to. However as wrong as it seems if it was sleeved i couldnt think of any reason to AR it.
it was in a hospital/old peoples home, so IDing it was to be avoided for as long as possible, but there was also no high ventilation or extraction (although not effecting combustion), they were using the plant room for storage and half the plant room was full of combustable looking rails of clothes. no earth bonding with electrical flex attached to every bit of gas pipe i could see
rough choices, who'd have thought box ticking would be so hard, life aint easy for a gas man
Looks like it could be ab?
That changes things!
I cannot see the pic properly because it's a bit blurred.
Does it look like asbestos to you Ambrosia?
Story of my life lol
Sorry, just re read the post above and you mentioned it yourself.
I skim read it before.
Reply to what do you guys make of this in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper end of DIY and I've a couple of house renovations under my belt (my own homes) I am retired but do volunteer handyman jobs for the elderly. Not...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
