Discuss What heat only boilers don't require pump overrun? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
R1CKY
Besides the Baxi Solo HE?
Brother in law popped round earlier to say his Glow Worm Micron 40ff is leaking and something electrical blew up! Looks like I'm replacing it on Sunday! As per usual of British House Builders, they've put the boiler at the opposite end of the house to the airing cupboard and decided to fit weyroc flooring everywhere! So running a new cable is not going to happen on a Sunday!!
Can't think of any except the Baxi!
I don't think the Vieesman need a pump over run.
I'm sure some on on her mentioned they had issues with a viesmann overheating when fitted with no pump over run.
Temp wire it, then fit a decent boiler. Vaillant preferably. 7 year warranted, do the course then register it.
Or go round the outside in horrible conduit like BG subbie sparkles do, seen loads round our way on WB RI's, seen it even from down to upstairs like this, outside the back in, not on my roughest job would this happen, always to a work around....
Was thinking of nail clipping it to the ceiling at 1M intervals, to the door frames (cutting a notch in the door), to the bannister, along the skirting and in to the airing cupboard (via another notch in the door).
Seriously though, looks like it'll be the Baxi, needs to be as cheap as possible, was hoping there would be an similar priced equivalent with a better warranty! My labour is getting paid in van bodywork repairs on this one!
Reply to What heat only boilers don't require pump overrun? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Vaillant ecoFIT 415 open vent heat only boiler. For wiring the boiler and pump, should I use the 3-way wire switch" solution OR a "remote...
What is the ideal pump size for Vaillant ecoTEC Plus 400 15kW Heat Only Boiler? The property is a studio with 1 large room, a small kitchen and a...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
