Discuss WHAT IS 10mm wire ????????? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pierre
When people talk about 10mm wire for electrical shower ( 10.5kw), Is it the measurement of the diameter of a single cable ( the live for example) or is it the diameter of the whole 3 wires coated??
Sorry, amateur.. ;]
Thx!
if you dont know and are thinking of putting in your own shower, stop now. If you are having some one do it for you get them to show you some 10mm T&E
All right. Thanks every one for your answer and warning. I took my caliper and measured the diameter of a single wire coated : i got 5mm. But it doesn't mean it's a 5mm wire, right?
Or in other word, how can i make sure my wire is a 10 sq mm? How to measure it?
ThX!
A 10mm2 is approx 3.5682482323055424mm diameter so all you have to do is measure it ;)
Except if it's stranded, the effective csa will be the sum of the individual strands rather than the area of the bundle, so you'd expect to measure a larger diameter.
Or just look at the markings on the sheath?
If you are turning the air blue with expletives because it so awkward to work with and expensive to buy, the chances are you have 10mm T&E 6242Y
you will know its 10mm2 when it only just fits inside the terminals of the double pole switch and shower.
If it's not 10mm twin and earth then you will have an electric fire instead of an electric shower - easy!!
Reply to WHAT IS 10mm wire ????????? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I currently have an 8.5kw electric shower on a gravity fed system in bathroom which doesn't give great flow when hot turned up but to get a 10mm...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Objective: I have an existing s-plan plus (see below for details) heating and hot water system, with 2 independent heating zones. There is a...
3K
Hi, I would really appreciate your thoughts, especially given the current climate we're living in. I moved in January to a property which only has...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
