Discuss what is class B pipes in UPVC in the Industrial Plumbing Advice Forum area at PlumbersForums.net
ABU
Am doing external work, what is called Class B pipes in UPVC
Reply to what is class B pipes in UPVC in the Industrial Plumbing Advice Forum area at PlumbersForums.net
