Discuss What is the best make of Angled radiator valves in the USA area at PlumbersForums.net
I have 10 radiators with smart TRVs fitted to angled radiator valves - some of these valves are weeping around the plunger shaft - the valves were fitted in 2012 and 8 years seems a short life (I suspect they were cheap!), so I want to replace all 10 valves with better quality valves - but need advice & opinions for which make of valve will give long, reliable life.
Also, does the entire system need to be drained down? (I've seen some YouTube where some nifty work with a wet'n'dry vacuum cleaner negates this). Oh and ideally I need someone to do the job (Marlow, Bucks).
Danfoss, pegular and Drayton are the common domestic decent ones
If you have smart trv heads as mentioned in the first post you will need compatible valves to fit them onto.
Standard trvs I prefer danfoss
Reply to What is the best make of Angled radiator valves in the USA area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
