Discuss What is the best pipe slice? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I couldn't see another version od this topic.
In order not to buy every pipe slice make out there. ...
Does anyone have a preference?
I find even good old rothenburgers fail just a frequent as the cheaper makes. I jave tried wd40 and ot just makes it so it takes 1000 turns before it cuts.
Any advice?
Thanx
Any advice?
Thanx[/QUOTE
Kopex was always a favourite, I have had them, but don’t seem to last as long. Rothenbergers ar usually good as are monument. Only tried one cheap one (city plumbing) and didn’t last long.
Kopex was always a favourite, I have had them, but don’t seem to last as long. Rothenbergers are usually good as are monument. Only tried one cheap one (city plumbing) and didn’t last long.
I've always used kopex but got my eye on the nerrard ratchet pipe cutter that does all the sizes and has a handle on the end. As even as someone who hasn't reached thirty years old yet I can suffer with hand pain after a days worth of pipework nowadays
Any advice?
Thanx
FWIW, my experience is to buy spares wheels for whatever make you buy. I used to use Kopex & Monument.
I also found that as soon as it starts to wander, strip it right down, clean it properly and apply just a film (DO NOT BLATHER) of silicone grease to where the cutter slides and also to the ends of the rollers.
In my experience that takes it back to new.
#YorkshireSkinflint ;)
Any advice?
Thanx[/QUOT
Nerrad pipe slice for me all day long. A little pricey but top notch cutters.
Not a fan of Kopex myself, had a rothenberger for a couple years with new wheel every now and then. Currently using Arctic Haynes pipeslices which are a nice blue colour which helps find them when misplaced, they’ve so far last a long time and also happen to be the cheapest in my local merchants! ;)
This is so weird, sad and pathetic but here goes, last night I dreamt I had bought a new 15mm pipe slice to replace the old that had to be turned about 40 turns to cut (tried bending the spring) and today I went looking for it in my toolbox but it wasn't there it was all a dream but so vivid. :(
Any advice?
Thanx
The one that cuts the pipe when i need it to.
Have you not seen/tried the ratchet ones?
Reply to What is the best pipe slice? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
