Discuss What is the direct replacement for this pump? in the Central Heating Forum area at PlumbersForums.net
This circulator pump has broken in the house that I have just moved into.
It seems the part is no longer made, does anyone know which model would fit into the same gap?
As an aside, what do the model numbers mean - 15-60 130?
Thanks,
David
Wilo or DAB.
Grundfos aren't what they used to be. They're the worcester of the pump world. Living on a long gone reputation.
The wilo is the yonos. They do a 5m and 6m version.
The 15-60 130 on the grundfoss are 15mm bore, 6 metre head and 130mm face to face as the width.
Reply to What is the direct replacement for this pump? in the Central Heating Forum area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
