Discuss What is this part? in the USA area at PlumbersForums.net
Hello everyone,
I have recently had a leak under the sink and a short investigation I found this part on the photo cracked. This is a part of the cold water flow and goes straight to the tap.
For self-training purposes (I have currently zero experience in plumbing) I thought that maybe I could replace it myself, but I don't know what is this part.
Can someone please help me identify it?
Also, does it look like someone unexperienced like me can fix this? Any related links, guides, videos, etc are welcome.
Thanks!
Needs carefully measuring but looking at scale that's probably 8mm copper to 15mm copper. You need a 8mm x 15mm compression connector ,search screwfix . Probably need a short end of 15mm copper tube and compression olive to renew back to tee.
Could also be 10mm copper so measure carefully!
Just needs the male iron remaking with more ptfe tape (the middle joint on the reducer)
It looks like there are two reducers: 15mm to 1/2 inch and 1/2 inch to 6mm, the latter needs to be replaced. It's kind of difficult to find that reducer or 15 mm to 6mm straightaway, so I wil have to search for other combinations too.
Reply to What is this part? in the USA area at PlumbersForums.net
Hi I have a kitchen mixer tap which allows the top part to pull out as a hose (like american sinks). It has frayed and I need t replace it, can...
Hi guys. I've been running an UFH installation/ repair business for 7 years now and one of my main frustrations is finding the parts for the UFH...
Hi, I hope to adjust the shower mixer tap temperature by adjusting the physical device regulator, that goes by several names/terms. I have...
Want to replace my old sink with a vanity. Can someone tell me what type of pipes the photo in the below links are and can I use compression...
Hello. My bathroom sink faucet is leaking and I would like to replace the hot ceramic disc stem cartridge (Sepco watermark 15) . I was able to...
