Discuss What kinds of plumbing pipes do I have? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello. I'm new to this forum and I'm hoping to be able to learn some things as well as contribute as best I can.
This might seem like an odd query, but I need to determine what kinds of plumbing pipes I have, and approximately what percentage of each type. I'd appreciate any help with this.
Please look at the attached photos (in this post and the next). As far as I can tell, I have copper, PEX and ABS plumbing pipes.
1) Is that correct, or am I wrong about the types of plumbing pipes that I have (copper, PEX and ABS)?
2) Have I missed any types of plumbing pipes?
3) I know that it's hard to tell, but extrapolating from the attached photos (in this post and the next), approximately what percentage of each type of plumbing pipe do you think that I have throughout my home (e.g. copper x%, PEX y%, ABS z%, etc.).
Thanks in advance.
Additional photos are attached, as per my prior post.
Would say 80% pex b 20% copper should be stamped on either part L or m
You need to check the red pex as there was a recall on one type should be written on the side of the pex somewhere
100% abs waste pipe
100% abs waste pipe
Thanks for the response. What percentage would you say is regular pipe to waste pipe? Is it 50% to 50% or is the ratio something else?
As water pipes to waste
Would say 65% water 35% waste this is an estimation
Reply to What kinds of plumbing pipes do I have? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
