Discuss What room stat do I need for boiler in the USA area at PlumbersForums.net
Hi all , I have a caravan with a valiant eco tech pro and I want to add a simple room stat as the boiler has a timer , can you recommend one please .
howy
Honeywell t3 or t3r for wireless
Honeywell 6360b old mech room stat no program
I didn't think caravan's had room thermostats? You can usually use the timer without one, just the boiler thermostat. Be wary of the Honeywell mechanical ones, I've had a few fail, and some of the new wireless ones as well.
A free standing unit would be better and more controlable Honeywell T4 is my choice , and don't fix it to the caravan external walls because of varying tempreture differences . Kop
What timer is currently fitted to the boiler?
Analogue the one on the front with little pins 😊
[automerge]1596521796[/automerge]
Hi , maybe I’m running it Wrong but without thermostat caravan is to hot !
Reply to What room stat do I need for boiler in the USA area at PlumbersForums.net
