Discuss What we all working on this week ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yep put a few prices in recently and thought they might get one done all three have come back go ahead
the walls are a nightmare, 1/2 a shift just to get the flue through.
Fit a MegaFlo (Which leaked on the probe pocket from factory) sorry for poor pics, was a really tight squeeze! Bit of servicing, back to finish off that big bathroom on Monday (Mirror, Towel Rail) then start another bathroom Tuesday.
Just been to unblock a WC for a friend of the missus. She's flushed down one of those plastic fresheners that clip over the rim of the pan.
I undo the cold feed round the back, take out the screw from one side of the pan and realise the other one is hidden by tiles/boxing-in. Tell her I'll have to remove the obstruction to get access. After she makes a quick call to someone she says she doesn't want me to do that so I put everything back as it was and charge her £30.
She's still got a blocked WC and it's the only one in the house. She seems to think she can get someone else who can do it without breaking her precious tile which, by the way, she has spares of.
All I needed to do was remove the other fixing screw, pull the pan out and reach in to remove the obstruction. As I was leaving she had a plunger in her hand.
Sunday night favours eh?
Edit: £30 has just landed in my account.
At least you got the £30 though.
Another bathroom job started all the old stuff is out the damaged walls and ceiling have been reboarded and skimmed, now putting it back together a split stone wall and floating furniture was a challenge on a metal stud plaster board wall 🫣. Kop
Quiet one today. Thankful for it, last week was heavy with that install.
Control box and magic eye on a mectron burner. Look at a job to install 6 designer rads, want pipes out of wall. Wayrock floors.
And.
Swap out knackered trv on a sealed system.
Then van turned poorly, rear pads, couldn't get it in till next week so managed to pick up a set and swapped them over. Real value for money on the old ones and lucky not to mess the discs up.
Got the lights and fan done a absolute mare with blown in insulation I had to remove it all fit hoods over the new lights to keep it away I'll lay more insulation over the flex to help avoid condensation 🙁 kop
Busy few weeks doing and old farm house up new rads, kitchen and bathroom also f the last installer who installs drain offs in a floor void I’m guessing someone ran out of caps
Also running a new 35,22,22 supplies as the old ones burst in the cold spell found out why someone’s cut the insulation to fit the timbers :D and 4 main cables in there 4x70mm 3 phase and two 3x25mm and a 25mm earth spent a week cable managing them as there like waves and in the way
Bit more done I got the boxing in completed first fixed the bath shower mixer, tanking and tiling well on the way the niche took a bit of time 🙁 . Kop
Getting there on this one but over commited so means not there today I am fitting a Home boost pump and Saturday is now another work day fitting a brushed brass fancy shower door that's taken 6 week to arrive 😕 kop
Finally done this one took 6 weeks for shower doors to arrive have a restful weekend chaps .
👍😉 Kop
Cracking on with this one this week my work load is off the scale are you all insanely busy ? the phone hasn't stopped I'm leaving it now on answer phone and deal with it at the end of the working day . 😉👍 Kop
All change for toilet cistern boxing in 🙁 which is a pita messed my tiling up sure I can work something out but annoying, I didn't have the cistern till Tuesday the flush pipe is not cut able so needed to get creative 😉👍. Kop
Finished another bathroom, heat only to System boiler and new rads (system was corroding like mad, had a 4 year old rad blow on pressurising) bits of servicing and jobs.
Wavin ?
Still finding frost damage
Little tsat took me a full day to find this little fecker was loosing air pressure but couldn’t find where had to turn the water on
And wait an hour
Another bathroom upgrade started this week splash panels on two walls for a large shower cubical , it all stripped out and patching up well under way , a new floor going down plasterer due early doors next week 👍. Kop
Are you able to drill a 6" hole in a wall for me? This became fit and wire a heat-recovery extract fan. Seemed decent quality, but not installer-friendly. I have suspicions the plate heat exchanger is too small to do a lot, but customer supplied it, so ho hum.
My day being a spark and look no rubbish :D
Reply to What we all working on this week ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
5K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
I was on this forum a long time ago and I would like to explain my experience of plumbing. This may be a long post but I will be happy if it helps...
2K
Hi, I need advice from experienced plumbers please, I got my bathroom done a few weeks ago, the job was done but the detail was very poor. I had...
4K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
