Discuss What's a rough costing of replacing an Eco 7 hot water tank? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sportyruss
Hi all,
I think I have a leaking hot water tank for my Economy 7 system. It's the type with the two immersion heaters. I was wondering if anyone can give me a rough idea how much this would cost to do, and how long a job like this would take.
Any info would be greatly appreciated
In answer to your question, ÂŁ625 and I'd be done by the time you get back from the cash point.
Do you need a new tank ? it could just be the gasket on your immersion
Well, I think so. I had the two immersion heaters replaced, and I think the top one was hard to remove and this may have damaged the tank.
it could also be the thermostat tube that has holed, either way it will have to be drained off and try to undo for the element to come out.
Reply to What's a rough costing of replacing an Eco 7 hot water tank? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
