Discuss Where can I get a custom made connector? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
rhobson897
I am looking to try and make a automatic watering system for my greenhouse.
I wanted a central tank to store the water, using a connector that I have in my mind (can only be best described as a spider)
One connection straight upwards, with several (maybe 6-8) connections spread evenly below this one upright connector.
As you can probably tell I am not a proffessional plumber, I wanted to try and find somewhere I can get a quote for such a connector, or preferably if anyone knew where I can buy something similar already.
TIA
That could be fairly easily fabricated from copper fittings. Have a look in the plumbing aisle of your local DIY shed then head off to your local independent merchant to buy what you need.
its easier to use the stuff thats made for irrigation i thought about making it up from stuff in stock but went with the dedicated stuff as it all fits together with things like drippers and sprays
Reply to Where can I get a custom made connector? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
