Discuss Where's the water coming from?(Vaillant boiler internal) in the Central Heating Forum area at PlumbersForums.net
Hello again
I just had a problem with a leaky flu which has been fixed but now I notice there is also a water appearing in a tiny pool at the base of the boiler. Am I right that it's the water leaking from where the central heating return pipe enters the boiler ? Is this a difficult fix?
Vaillant ecotec
Thanks again for any advice!
It’s likely to be a component, and shouldn’t be a difficult fix.
That particular boiler‘s cover forms part of the combustion circuit, and needs to be worked on by a competent engineer, gas safe registered engineer in the uk.
Reply to Where's the water coming from?(Vaillant boiler internal) in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
