H
Heating-eng
Re: Which Central Heating Filter to go for?
I would agree the TF1 seems to be the best . I wouldnt fit the magnabooster 2 unless thats what the customer wanted.
Hi All
I'm getting my boiler changed and want to fit a central heating filter at the same time, but am wondering which is the best to go for, as I've seen a few different types but aren't sure on their differences. I've also read that the filters can leak, so is there any advice on that, e.g. fit separate full-flow isolation valves on either side of the filter, in case the filter fittings start to leak?
I've seen the TF1 for £81:
Fernox Total Filter TF1 Magnetic Filter
which is labelled as a magnetic filter, but on reading the description also removes non magnetic contaminants!
I've also seen the Magnaclean TwinTech for £116 which is a magnetic and non-magnetic filter:
Central Heating Filter – MagnaClean TwinTech
Then there's the Sentinel filter for £124 which is also a magnetic and non-magnetic filter
Sentinel 22mm Magnetite System Filter [SYSTEM-FILTER-GB] - £123.90 : UK Plumbing, Online Shop
So I'm a bit confused as to the differences between them. The price difference between the twintech and the sentinel isn't much, but the TF1 is quite a bit cheaper, so was wondering whether I'm missing something and in your experiences which is the best to go for?
Also how long do these filters actually last for, do they need changing every couple of years or so?
Thanks.
