Discuss which quiet and reliable combi boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sebastienj
replacing my boiler+cylinder with a combi boiler.
the boiler will be located in my bedroom so being quiet is a must and of course it also needs to be reliable and cheap to fix.
7 rads
1 en suite
1 bathroom
many thanks
Getting a very strong sense of deja vu...
I thought you were sold on the idea of an Intergas???
viessmann 100w (the new one)
yes except that it 45 dB. i have read spec where the noise output is 32 - 35dB
hence why i am asking again. apologies
Can I ask why it is going to be in your bedroom? it is not too difficult to re route when changing,
No need to apologise - I hadn't seen your post on the other thread.
45dBA is approximately as noisy as a computer fan. Really not noisy at all - in fact, unless your hearing is hypersensitive you'd just tune it out. If the boiler is going in a cupboard then you'll be pretty much unaware of it operating.
Found the intergas very quite and also Ideal boilers seem quite to me, dont know the exact db level though
I find the ideals are noisy, especially the Vouge!
Reply to which quiet and reliable combi boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered...
Been a retired plumber now for almost 20 years so a bit out of touch with the trade. I am wanting to replace a combi boiler . What is the most...
1K
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
1K
