Which unvented indirect cylinder
View the thread, titled "Which unvented indirect cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
Ro74
I am looking for some advice on which 150litre indirect invented stainless cylinder to buy. We were going for a Gledhill, but the plumbers merchant is suggesting an Elson Zircon would be as good, but cheaper. Any recommendations on which to buy, or any other better brands would be much appreciated. It would be working with an existing Worcester Bosch, Greenstar, highflow 440 floor standing combi. Thanks
We haven't had that advice yet, speaking to a few different WB approved installers so that we can get some servicing on the boiler at the same time as the cylinder installation. Just looking for some back ground advice so that we can proceed with a bit of knowledge.
I personally like Vaillant cylinders.
They, along with other manufacturers do a dual coil cylinder ( The Aurastore ), which is good if you may be thinking of adding solar panels now or even at a later date.
Rule 1:
Don't take advice from Plumbers Merchants if you don't know much about the products you require.
These guy's are good at selling products with the highest margins for them, and take no responsibility for them after installation.
It would be best to take recommendations from installers because they are the ones you will be calling when things go wrong.
Once you have recommendations from the installers then you should do searches on the products they recommend.
Santon
RM
There are plenty of good makes tbh, normally follow your installers advise as they will have a preference based on installation and servicing experience. Whichever you go for make sure it's serviced every year with the boiler.
Ahem!
Any source of advice can be biased, and it always helps to understand the potential bias of the advisor when evaluating their input.
Hi Ray,
The statement was fairly broad....and based on seeing homeowners end up with something that doesn't suit.
You don't deal with the General Public, so you are fairly sheltered with advising what items / systems they require and what is suitable to be installed.
Over the years I have been asked to install appliances / systems that customers have bought themselves through advice from Plumbing Suppliers.
1: They pay way over what I would pay for the materials / equipment.
2: A lot of the time the equipment is not correctly sized or suitable to be installed in the property.
I'm not saying Merchants aren't entitled to make money, nor am I saying Plumbers aren't biased towards brands and products.
At the end of the day, this customer wants to find out what systems are suitable for his situation. It would be best for him to have a couple of reputable plumbers give him advice on what is best for him.
He doesn't know what is best for him, that's why he went to the Merchants first and then came on here to see if what the Merchants suggested are suitable.
He may end up buying something that no one wants to install - nor guarantee the installation
His first port of call won't be to the Merchant that supplied the goods, it will be the Plumber that installed the system.
if customers want to supply themselves, they are usually advised that any guarantee is between them and where they purchased the materials. the only guarantee offered by the plumber/gas engineer will be for their workmanship in fitting said item/s. any problems and they will have sort with their supplier.
Reply to the thread, titled "Which unvented indirect cylinder" which is posted in UK Plumbers Forums on Plumbers Forums.
Ro74,
PlumbBobBob,
