Discuss whirlpool bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adrianfs1
hi all just a short query, fitted whirlpool today alls well, sparky sorted electrics this afternoon before flying out on his hols(lucky git) howerver came to fit bath panel this evening and found an earth wire that is still wrapped in its factory tie and attached to the pump, im assuming this earth wire just needs bonding to the bath metal framework, sparky did say ring him with any probs but i really dont think i can get hold of him, are my assumptions correct, please help want to wind up this job tomorrow morning if poss, cheers all.
does nobody know the answer to this question, surely all u experianced plumbers know the answer to this.
Hi. Always an iffy situation assuming earthing requirements without seeing the situation. Personally i would give the manufactures technical dept a ring. In order to get clarification on the situation. Its difficult for client to write out your check if the water and electrics mix whilst taking a bath.. Good Luck
thanx for that mate atleast someone replied, will speak to whirlpool in the morning, cheers
Reply to whirlpool bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Recently moved new flat (end August), on second floor, 70s block with low water pressure (10 storey). 2 bathrooms (back to back). Warned by agent...
2K
  • Locked
Hi Our mixer shower has always run slowly with very low pressure (taps seem fine). We asked around and one electrician suggested a dual pump but...
2K
jase158
J
  • Locked
Hi All, Fitted one of these about six weeks ago, was a nice job (thankfully in a bungalow, concrete floor as its a touch on the heavy side), if a...
3K
adrianfs1
A
R
  • Locked
we've just had our bath fitted and must have knocked it as the is now a leak coming from one of the joints from the whirlpool pump we are unable...
8K
G
  • Locked
Guys In response to my central heating bioler failing (long story , £3k quote from plumber, and I can't afford it due to recession).. I have had...
1K
greenprodrive
G
