Discuss whistling sound from pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, I waited a while before I posted this as I wanted to see how long the issue would go on for.
There is a whistling sound from the pipes next to the bathroom but not when I use the water in my flat but whenever my neighbour does who lives below me. Everyone got disconnected from the water tanks for the bathrooms and all flats are now mains fed and PRV's have been fitted which no one had before, so I don't know if they are set too low or high.
Any idea why the pipe whistles and what can be done about it, thank you.
Frequencies I'd describe as 'whistling' (as opposed to a 'hum' or 'honk') are a bit high for a resonance associated with the pipework to be a likely cause.
I'd start by investigating the taps. If these were not changed to high-pressure ones, people avoid getting soaked by a blast of water by cracking them open. This creates a pressure jet inside the tap that can make a whistling noise when it strikes the body.
If my guess is right, reducing the pressure set by the PRV may help (and might be a useful confirmation of the cause) but you'll probably have to install a restrictor for the tap or replace the tap for a proper fix.
Reply to whistling sound from pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hi everyone, Just wanted some confirmation regarding a PRV fitted to the mains supply in my building. All 6 flats in the building are now...
Hi I've got water hammer issues with my cold feed and some with the hot feed. When the cold sink tap, cold bath tap and thermostatic shower in...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
