Discuss Why are fan convectors meant to be on Constant Temperature circuits? in the Central Heating Forum area at PlumbersForums.net
T
Toby1996
Why are fan convectors meant to be on Constant Temperature circuits? I originally thought that it was because they aren't suitable for lower temperatures, but I recently found that no to be true since you can use them at 55/44 flow and return temperatures (Oversized).
Radiators go on variable temperature circuits, and they can benefit from being weather compensated.
Why is it not recommended to do the same with fan convectors? (Put them on the VT)
So you can set the temp the fan comes on it’s not variable
Reply to Why are fan convectors meant to be on Constant Temperature circuits? in the Central Heating Forum area at PlumbersForums.net
C
Newly bought home has somewhat older plumbing, but recently fitted condensing gas boiler & HW cylinder. System is open vented. When we moved in we...
combedcloud22
C
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
1K
H
HRP123
H
  • Locked
Hi all My name's Paul and I'm in County Antrim, N. Ireland. I'm pretty good with pretty much any DIY stuff bar plumbing! I've just joined the...
7K
G
  • Locked
I have a holiday cottage in a remote location without mains gas. The lpg hot water / central heating system has a recently installed high...
5K
mooreofdevizes
M
