Discuss Wilo Yonos Pico pump - venting question in the Central Heating Forum area at PlumbersForums.net
Hello
When I choose the the venting function what does it actually do? Do the pump have its own vent hole? Do I need to vent the radiators while it's doing this?
Chris
No, there is no magic vent, the venting function keeps speeding up and slowing down the pump for 10 minutes?, I didn't (have to) use that function in mine on installation and yes you still have to vent the rads/system.
I would normally vent the rads with the boiler/circ pump off, from the bottom floor up, then run the boiler and heat up the system and shut down again and re vent as necessary. I would suggest running the pump on constant speed setting II while system is heating up, if you like I can then advise on the final setting.
Reply to Wilo Yonos Pico pump - venting question in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
