Discuss Wireless Honeywell T3R with Glowworm Ultimate in the USA area at PlumbersForums.net
Hi all, I’m not a plumber but looking to change my parents Dial Thermostat & potterton programmer to a Honeywell wireless type .
They currently have a Glowworm ultimate boiler and the programmer does the heating & hot water (cylinder) separately once / twice a day or off .
I do have a wireless Honeywell T3 (honeywell home) programmer/receiver but I’m thinking it won’t be compatible as I think It only does the heating and not the hot water ?
I use the T4 and it so much better than my old dial thermostat that I’d like my elderly parents to be able
Control their heating more accurately with easier access than their hallway wall mounted one .
Any advice would be a great help , I’ll be using a local boiler engineer / plumber to fit so just wanted to find out about these first .
Thanks , scott .
D2C1748C-7E4B-418B-AEEB-9E7354F8F637.jpeg911AC05B-512E-4847-8C66-EFCE0A87C116.jpeg49C3A0F1-3708-412A-B373-637EFEB7B7C6.jpeg
You would have to leave the original timer there and just replace the room thermostat due to the system being two Chanel
Ok thanks Shaun , so then this T3r receiver will replace the existing thermostat and can then be controlled by the new digital one -7 day programming & temp ? If so what happens with the CH timer settings on the old one ? Do they get bypassed ?
thanks scott .
The receiver can go up in the airing cupboard with the cylinder and wiring centre
and yes either modify the existing wiring in the wiring centre or just move the ch on wire in the prog to the live terminal so it’s live all the time
Tbh, i'd return the Honeywell and replace it with a Hive.
Fit a lot of Honeywell stuff and really like it but the new stuff and old people just don't mix well.... the Hive is simple to use, it walks you through all the settings, it has two nice boost buttons for HW and Heat, you can put it in stand alone mode (So don't need to use the internet connected stuff). For £130ish they're a bargain in my opinion.
Reply to Wireless Honeywell T3R with Glowworm Ultimate in the USA area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
