Discuss Wiring a drayton digistat to a Worcester greenstar combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Elemental
Hi there
Can someone please help me I want to wire a Drayton digistat to a Worcester bosch greenstar 24i. According to Worcester Bosch , LR is wired to ON, LS wired to COM and NS TO N (neutral) but the thermostat doesn't seem to work. Have they given me the wrong info?
You need to take combustion case off the boiler to access terminals. This is a very important case seal. If you do not put it back on properly 75% chance u will die. 99% chance of rain.
Get a gas safe engineer in.
Thanks Ermintrude you really helped me on that one, everyone likes a smart bum I am a Gas Safe engineer.
Why don't you join the gas engineers section gladly answer in there stops joe public from seeing
It was indeed. You shouldn't be opening this boiler up unless you're a gsr.
Please see the forum rules for gaining access to the private forum.
Reply to Wiring a drayton digistat to a Worcester greenstar combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
