Discuss Wiring a Hive Receiver to Worcester Bosch Greenstar 4000 30kw in the Central Heating Forum area at PlumbersForums.net
Hi Everyone - despite my best efforts I can't seem find a clear answer on how to wire a single channel Hive Receiver to a Worcester Bosch Greenstar 4000 30kw. I've attached 2 photos showing the connections on the receiver and boiler. With great hope you experts out there can help - thankyou!
Looks like extra low voltage of 24v isn’t supported unless you use Worcester accessories, so you need to provide a permanent live and permanent neutral plus switching. Looking at the diagram on the left of your Worcester attachment (240vac) you might be able to use one of the L out and N out, then link L at hive receiver to terminal 1 (common) and then take a wire back to LR. So best using 4 or 5 core flex.
It’s on the 240 v side
240 out goes to your controls
Lr is your switch back eg fire
So 240 out block
L to L on hive
N to neutral
On hive link L to 1
3 to Lr on boiler block
Reply to Wiring a Hive Receiver to Worcester Bosch Greenstar 4000 30kw in the Central Heating Forum area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Sonya K
